2008 Trailblazer???
Old Sep 12, 2018 | 08:51 PM
Aardvark's Avatar
Default 2008 Trailblazer???
Ok I’m new to this but here goes... So I have a recently acquired a 2008 Polaris Trail Blazer 330 and I’m having a problem keeping it running. The problem 1) starts but dies after 10-20 seconds idle
2) will not rev up after starting, give throttle it dies
it however fires right back up
i have done this so far with same results
1) new fuel and lines
2) new carb and fuel pump
3) new carb boots and air cleaner
4) new spark plug nice bright blue spark
5) I scoped the jug with a camera and looked great, has good compression, valves looked cleaned inside
6) new battery
i felt it was a fuel issue however I’m thinking maybe electrical?
Old Sep 18, 2018 | 02:17 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
make sure the etc has slack in the cable at the throttle to eliminate the over ride kicking in.
Old Sep 18, 2018 | 08:22 PM
Aardvark's Avatar
ETC checks out good works as it should, I got some feedback on the air box being temprimental. Cleaned all seals replaced boot and still starts runs then dies.
Old Sep 19, 2018 | 01:03 AM
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
It needs, fuel, air, spark, and compression to run. If all those all check out I think timing would be next on the list to check. If it's a cheap aftermarket carb that can be a problem too.
Old Sep 19, 2018 | 02:40 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
what happens if you are choking it while it starts to die or rev up? trying to see if it's a lack of fuel issue
Old Sep 19, 2018 | 04:49 PM
Aardvark's Avatar
If it’s choked or not it starts right up but won’t rev up or change runs like 15 seconds then dies. Now yesterday it started and ran until I tried giving it gas. It’s just like nothing allowes it to rev up.
rgjackson
Sep 17, 2015 11:21 AM
broadfieldpoint
Apr 12, 2010 03:45 PM
Sportsmanfanz
May 24, 2009 01:47 AM
trailblazer_02
Utility ATVs
8
Oct 23, 2008 01:01 AM
Raptor350SE
Sport Quads
Jun 24, 2007 08:05 PM
