Needing help 2002 kawasaki bayou 220 starter wire problem
Old Sep 12, 2018 | 11:48 PM
Arkansas,Paron's Avatar
Default Needing help 2002 kawasaki bayou 220 starter wire problem
I have a 2002 kawasaki bayou 220. I'm trying to find out were the big red wire coming from the starter goes. someone had put the big red wire into the accessory terminal connector the one under the seat. I'm pretty sure that's not where it goes can anyone help me find the correct place for it.
Old Sep 13, 2018 | 02:54 AM
There will be another big wire from battery positive to the solenoid/main fuse. That solenoid has another binding post terminal on it and your loose red wire connects to it. However someone has disconnected it for a reason, so I wouldn't expect it to work when you do fit it back on the solenoid.
Old Sep 16, 2018 | 10:17 PM
Well It has been plugged up to the accessory power connector since I got it from the shop but I now that someone screwed up and didn't put it were it's supposed to be do u have any pics of were the red wire connects to and have u seen my picture of the wire how they had it connected its in my images on here I can't figure out how to post it here on the comments
Old Sep 17, 2018 | 01:57 AM
No pictures, I haven't worked on a 220 for a couple of years, I just checked the wiring diagram someone has posted here recently, and the solenoid is where it goes. Like I wrote, follow the thick pos from battery, that goes to a M6 binding post on the solenoid. Other M6 binding post on solenoid should have the thick wire to starter on it.
Blastapest2
Jun 26, 2018 01:59 AM
Kimberly Kirkman
Technical and How-To Articles
May 25, 2017 01:42 PM
PhilipR08
Feb 24, 2015 11:09 PM
Arkansas,Paron
Nov 4, 2014 05:30 AM
GORide
Sep 30, 2003 09:03 AM
