Awd not working, Polaris sportsman 700
Old Sep 18, 2018 | 11:47 AM
Rwad95b's Avatar
Default Awd not working, Polaris sportsman 700
AWD not working. AWD light comes on.
polaris sportmans 700
how I can know where is the problem?
i want to fix it by your help, cause here the The mechanics take a lot of money
Old Nov 9, 2018 | 03:59 PM
windsc's Avatar
What year is your 700?
There are two wires coming from the front differential that connects to the AWD coil. To get to the two pin connector easily, remove the front plastic access panel that is under the front rack. The grey wire should be battery positive when the AWD switch is on. The brown/white is the ground which is supplied by the speedometer.
If there is no ground present then you can bypass the speedometer by connecting the brown/white wire directly to chassis ground.
Battery positive goes thru the ignition switch, then to the AWD switch, then to the grey wire.
If there is battery positive and ground to the wires then you will need to check resistance on the wires. Grey to brown/white resistance should be close to 24 ohms.
chikester
Oct 9, 2018 12:13 PM
trbojet1
Oct 12, 2017 04:33 PM
briancbeck
Aug 3, 2009 05:44 PM
ericverk
Apr 14, 2007 11:03 PM
Albino1
Jul 21, 2005 11:24 AM
