Kawasaki bayou starting problem
Old Sep 21, 2018 | 08:58 PM
Jack d.'s Avatar
Default Kawasaki bayou starting problem
Kawasaki bayou 220 wouldn't start so I rebuilt the carburetor. Now it will start but only if you push start it and it will run great but if you use the starter button all it does is crank but wont start even after it has warmed up. Does anyone have any ideas?
Old Sep 24, 2018 | 02:42 AM
Low compression can cause this, as you turn the engine faster when push starting. Check it is over 90psi. If it is low, try adjusting valve clearances.
Old Oct 15, 2018 | 05:52 AM
Bayou58's Avatar
If the compression is good, then here is what I had to do on mine. When it was cold, or sitting for several days, it was so hard to start. The choke didn't do anything. I bought a rebuild kit, and still was so hard to start cold. MIne is perfect now, the choke works as it should, and it starts in a crank or two. There is a port in the bottom of the carb bowl, next to the gas drain hole, that needs to be cleared. It is small, and I missed it when I did my carb. I took a sewing needle, then some carb cleaner, and some air into the hole. You should be able to blow air or cleaner from the small hole at the bottom, and it will come out the larger top hole where the gasket fits. Good luck, let me know if it works !
Old Oct 16, 2018 | 08:33 AM
armed hiker's Avatar
check those valves if the compression is going right back out a valve due to it not sealing it can do this. At the dealership I used to work for people used to bring us plenty of Japanese bikes from the 80's that would push start only, in most cases the valves were sinking into the heads and all clearance was lost so the valve was always open. Note this can burn valves as the valves need to close to shed heat so at bare minimum get the motor to top dead center on the compression stroke and wiggle each valve (up and down) to verify you have at least some play.
c_quillen
Jul 21, 2017 09:48 PM
jcookschillin
Nov 12, 2008 02:26 PM
dealer
Jun 26, 2008 07:58 PM
pestosh
Jan 10, 2002 06:16 PM
Cawzican
Dec 27, 2001 09:03 PM
