choke plunger stuck?
Old Sep 30, 2018 | 03:27 PM
cjben's Avatar
Default choke plunger stuck?
pulling the carb on a 1999 bayou 220. I have everything disconnected except the choke cable. I can't get it out of the carb. I took off the plastic nut off and the cable still won't come out. I did pull on it with some force but really don't want to break anything. Is there anything else that needs to be disconnected?
Old Oct 1, 2018 | 03:05 AM
I rarely work on Kawasakis, but the choke plunger getting stuck on carburettors is common. Sadly, to remove it usually ends in destruction of the plunger. Firstly, pull hard, and the cable pulls out of the plunger. You then go in with narrow nosed pliers and tug at the brass bit, this breaks off. Only way then is to drill a small hole into the centre of the brass plunger, 1/4" down should do it, and insert a self tapping screw. Pull on that, and the plunger usually comes out. I have sometimes had to warm the carb body, but naked flames and petrol are not a good combination, and there are some plastic and rubber components that don't like heat, so that is a last resort.
hic-lock
May 3, 2016 10:52 AM
joebob57
Feb 10, 2012 07:51 AM
remi_357
Apr 8, 2011 07:25 PM
Mrmonk
Dec 30, 2003 11:12 PM
