2003 trailblazer 400 smoking
Old Oct 2, 2018 | 03:56 PM
Chris Ciesla's Avatar
Default 2003 trailblazer 400 smoking
My trailblazer smokes more than I think it should. Have been told they r supposed to and get that being a 2 stroke. Seems more than it should
Old Oct 2, 2018 | 04:02 PM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Are you using the premix reservoir or have you bypassed that and mixing the oil yourself?
Old Oct 2, 2018 | 04:03 PM
Supersock
Hired Gun!
Also, it is at least 12 years old, so needing new rings isn't out of the realm of possibilities.
Nice thing about 2 strokes, they are easy to work on.
Old Oct 2, 2018 | 04:09 PM
it has th reservoir
Old Oct 2, 2018 | 04:12 PM
Default At what temp should fan kick on and will it work if I'm not using a battery
Will it work if I don't have a battery
Old Oct 2, 2018 | 04:24 PM
Originally Posted by Chris Ciesla
it has th reservoir
what temp should fan kick on and does it matter if I don't have a battery
Old Oct 2, 2018 | 04:31 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
not having a battery could leed to issues with the charging system and maybe stator failing as your charging something that is not there. no issues with the oil pump not having a battery. it might be that the pump is set to high and giving you too much oil flow as well. it also depends on type of 2 stroke oil you use. it wouldn't hurt to do a compression test to see where your at. not sure of the fan temp but I suggest you buy a battery as it could save you in the long run.
Old Oct 2, 2018 | 11:55 PM
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
I agree with all of that. Running it without a battery can blow out all the light bulbs and possibly damage other components. I've been behind 2-strokes that didn't smoke much until the rider jabbed the throttle. In my limited experience, full-synthetic injection oil smokes less.
Old Oct 3, 2018 | 11:31 AM
DirtDevil101's Avatar
Rings will have nothing to do with the amount of smoke since it's a 2-stroke (rings on a 2-stroke are compression only...not compression & oil like a thumper)...your oil pump may need adjusting or perhaps you changed oil brand recently (the good oils burn far cleaner and still lubricate). Plugs have temp ranges as well...which may contribute...2-strokes generally smoke more when cold and clean up when warm (leaner running condition)...
I've NEVER had a problem running with a dead battery...and I've owned a lot for a long time...not sure where these comments are coming from as the battery is in no way shape or form a regulator...
My $0.02...
Old Oct 3, 2018 | 02:48 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
My $0.02...
KEY STATEMENT- "dead battery" it is not the same a missing battery!. and you just re stated what I said about the oil.
