Identify this part
Old Oct 11, 2018 | 05:42 PM
Sti1471's Avatar
Default Can anyone Identify this part?
I have a 1995 sportsman 400. I found this part on top of the skid plate below the engine on the left side, and it was covered in grease.
the atv runs good and I dont have any reason to think anything is broken. I'm not sure if I left this there from another project, or if it belongs to this atv and fell off from somewhere. Can anyone identify what this might be if it goes to this atv.
Old Oct 11, 2018 | 06:06 PM
94harley's Avatar
https://www.ebay.com/itm/OEM-2000-20...3:pf:0&vxp=mtr
Old Oct 11, 2018 | 06:19 PM
Sti1471's Avatar
I looked around with a flashlight and also found this part. Also greasy.
Old Oct 11, 2018 | 06:20 PM
Sti1471's Avatar
Originally Posted by 94harley
that likes different than this ring. Also that's for a 2000+ machine and mine is a 95
Old Oct 11, 2018 | 06:25 PM
94harley's Avatar
Looks like parts out of the rear axle eccentric on polaris scramblers, xplorers etc. Its been a while since I had to order one but I vaguely recall ordering the entire eccentric for an older machine and it subbed to the "new style" which takes that spacer. Has yours ever been changed?
https://www.ebay.com/itm/Polaris-Sea...2:pf:0&vxp=mtr
Old Oct 11, 2018 | 07:08 PM
Sti1471's Avatar
I dont think I have ever had them replaced. The green little seal looks like the front wheel bearing seal.
https://www.ebay.com/itm/Polaris-Scrambler-front-wheel-bearings-kit-400-500-1995-1996-1997-1998-2009/322224973273?rmvSB=true&pageci=24cf2b00-1b0
but I'm not sure what the metal ring is. From the grooves on the outside wall, it looks like it might have been the inside ring of a brearing from somewhere. If they were from a wheel I have no idea how they ended up on the skid plate. The only install I have done near where I found them was I replaced the front left side shock a while back.
Old Oct 11, 2018 | 11:08 PM
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
Don't you just hate it when you're done working on something and have leftover parts?
Old Oct 12, 2018 | 07:40 AM
scootergptx's Avatar
Supersock
Hired Gun!
Leftover parts? I prefer spare parts for later.
Old Oct 12, 2018 | 10:33 AM
94harley's Avatar
https://www.ebay.com/itm/Polaris-Scr...i=24cf2b00-1b0
It does look like a "front strut seal"(hub seal is actually about 1/2 inch thick) but it also looks like this rear housing seal. https://www.ebay.com/itm/Polaris-Sea...1:pf:0&vxp=mtr I was incorrect on the rear housing subbing to the new style, thats incorrect on my part. I think it subbed to a new number, but not a new style. Sorry. Memory gets worse everyday!!! The size of the collar, and the wear on it, resembles the collar on the rear axle of machines I have torn down in the past. Like you said though, its the later style and not the 95 like yours. Thats puzzling. Although if it is the parts i believe them to be, you have nothing to worry about because they didnt come off your machine. But the question now is, Where did they come from?????
Your rear eccentric should look like this - https://www.ebay.com/itm/98-Polaris-...0:pf:0&vxp=mtr
Which doesnt have the parts that you took pics of.
This style does have similar parts theat you too k pics of - https://www.ebay.com/itm/Xplorer-Rea...0:pf:0&vxp=mtr
RasBM
Apr 30, 2017 12:43 PM
NRXTM
1) Engine problems..
Apr 17, 2014 10:33 PM
bmurphy
Apr 17, 2014 10:30 PM
eightyhd
Dec 8, 2012 08:34 PM
NCSurveyor
Mar 11, 2004 10:03 PM
