1998 scrambler shifter micro switch
Old Oct 20, 2018 | 06:37 PM
paul edwards's Avatar
Default 1998 scrambler shifter micro switch
bypass micro switch
Old Oct 20, 2018 | 07:14 PM
looking for information on how to bypass the shifter microswitch
Old Oct 20, 2018 | 07:56 PM
94harley's Avatar
What are you trying accomplish? Do you to trick the machine into thinking it is in forward all the time? So the AWD will still work? I can look at a manual Monday and tell you how, but don't recall off the top of my head.
Old Oct 20, 2018 | 08:07 PM
yes I want the awd to still work in any direction.thanks
Old Oct 20, 2018 | 08:12 PM
94harley's Avatar
Ok. I'll look at the manual Monday and let you know.
Old Oct 22, 2018 | 11:55 AM
94harley's Avatar
Both 1998 400 and 500 scramblers - Jumper the red/white to the grey/white wire at the gear selector switch and the unit will "Think" its in forward at ALL times. Friendly reminder- reverse limiter will no longer function so it will go very fast in reverse after you do this.
Unplug it and jumper the "Harness" side, not the switch side and you should be good to go. Switch is in the shifter assembly, just follow the wires to the harness.
Pic for reference
https://www.ebay.com/itm/1999-Polari...1:pf:0&vxp=mtr
Old Oct 22, 2018 | 05:40 PM
thanks that's great!
dkerkman
Oct 4, 2016 11:15 AM
bigpollyboy
Sep 15, 2016 08:49 PM
TheLastPolarBear
Sep 3, 2016 12:40 PM
Garrett Moore
Aug 27, 2016 07:27 AM
2B
Jun 29, 2003 08:49 PM
