2005 sportsman 500 dead speedometer and gauges
Check wiring under the front cover under the center headlight. Cant remember the years but a lot if them had wires that would break in two due to the way the harnesses were built. If nothing, reply back and well get into voltage checks later.
Key on, run position on stop switch. Check for 12 volts(batt voltage) on pin 1 and 8, then pins 2 and 8.
pin 1 Orange/white
pin 2 Red/white
pin 8 Brown
If you dont have voltage there-wiring issue.
If you do have voltage there time to replace the speedo.
pin 1 Orange/white
pin 2 Red/white
pin 8 Brown
3280431 Asm., Cluster Retail 369.99 Cheaper online of course.
Got a used one I'd sell you if you dont mind used. Came off a 05 500 like yours. Pm me if ineterested.
canadianredneck
Technical and How-To Articles
13
May 23, 2016 03:17 PM
