Need some suggestions
Old Nov 6, 2018 | 09:41 AM
Serenity's Avatar
Default Need some suggestions
89 Trail Boss. So far I have replaced secondary coil, CDI box, rebuilt original carb and finally just installed a new carb last night. Disconnected reverse limiter switch black wire. On old carb I managed to get bike to start for about 20 seconds on full throttle and it died Nothing since than. After taking old car apart twice I decided to get a new one. New one will not fire up at all. I have not tested compression yet for lack of compression tester. Spark appears ok but I am wondering if weak. Looking for any suggestions where to go next. Main coil? Fuel pump? Any help is greatly appreciated
Old Nov 6, 2018 | 11:50 AM
94harley's Avatar
Drain the crankcase. Use a 10mm socket and there is a drain bolt in the very bottom of the crankcase, sits at an angle. Once you get the bolt out, insert something with a small diameter to verify the hole is clear(wire tie or something) If fuel comes out, it was flooded. Replace the plug and try starting again.
Compression test would be nice to know it showed.
That motor also had issues with base gaskets going out and crank seals going bad.
Old Nov 6, 2018 | 02:50 PM
Serenity's Avatar
94Harley to the rescue again Thanks man I will give it a shot tonight.
XJ4ME
Oct 14, 2004 12:23 PM
Len
Jul 20, 2004 08:36 PM
IowaBob
Feb 8, 2002 01:56 AM
shollz
Oct 13, 2000 02:35 AM
CRM3
Aug 6, 2000 10:27 PM
