Polaris 570 Touring, Fuel guage flashing HELP!
Old Nov 7, 2018 | 08:13 AM
bfofre's Avatar
Default Polaris 570 Touring, Fuel guage flashing HELP!
1st off...thanks for having me!! I just purchased new to me Polaris ATV for the family!
2016 Polaris Sportsman 570 Touring
I am looking to buy tomorrow another 2014 Polaris Sportsman 570 Touring
The 2014 has a small issue..doesn't effect the bikes function (running wise) but the fuel gauge is flashing on the dash.
I've read a ton about this...Seems like a common problem for the Polaris bikes.
Should i run from this?? or is an easy fix?
I've looked around the interweb and can't seem to locate for sale the fuel sending unit for sale.
Any advice asap.... Supposed to go pick this bike up tomorrow!!
Thanks for your advice in advance!!
Old Nov 7, 2018 | 12:44 PM
94harley's Avatar
Ive never had one out that specific model but have had several out of other units. What we always ran in to was the float itself is what is bad. Very SELDOM is it the float sensor. The material(not sure what it is) the float is made of, gets saturated(my guess) and will not float anymore. It will float in water, but drop it in fuel and it sinks. Its not a part you can buy separate from polaris. Maybe an aftermarket is out there now, but I've never found one. I have taken the float off another fuel pump that was bad that we have changed out and fixed it that way, but you have to find someone that has a unit with a bad pump assembly to get you the float. Its not a issue as far as running the unit.
I may have a float laying around but not sure. Would have to check if your interested if you do go get the machine.
My opinion, I wouldnt pass on a good machine for that issue. Worst case scenario the pump assembly gets replaced.
Old Nov 7, 2018 | 06:25 PM
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
I was going to say that someone else had the exact same problem, but it was the same thing posted twice. You only need to post a question in one area or the other, not both.
Daubs
Dec 24, 2018 03:52 PM
ejb7864
Nov 8, 2014 11:10 AM
outdoorsman26
Jun 20, 2014 08:34 AM
behindredeyes
Mar 7, 2007 11:16 AM
