Exhaust part discontinued
Old Nov 19, 2018 | 02:19 PM
DALE123's Avatar
Default Exhaust part discontinued
i have a 1996 polaris sportsman 400 4x4 - 2 cycle - that needs a exhaust flange that is discontinued - does anyone know where else i can look?
Old Nov 19, 2018 | 02:26 PM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Ebay is a good source for used parts.
I moved your post over to the Polaris section. The guys in here will be able to tell you more about parts availability and what other parts may interchange with it.
Old Nov 19, 2018 | 03:30 PM
DALE123's Avatar
thanks - you are spot on - i just found the two parts i am needing - one last question- the diagram did not show a gasket between the manifold & block - bit the used manifold shows some thing - can you suggest i=on what to use in its place?
Old Nov 19, 2018 | 03:42 PM
Supersock
Hired Gun!
Going by memory, so it could be wrong. I thought they just held with springs and no gaskets. I'll have to check the diagram to see.
Old Nov 19, 2018 | 03:45 PM
Supersock
Hired Gun!
Just like you posted, shows no gasket. I know on my trailblazer, there wasn't one and it was ok when I put it back together.
dwoodfin
Sep 15, 2016 10:06 AM
summit
Sep 8, 2016 07:30 AM
prohaulerismynemesis
Sep 1, 2016 02:23 AM
Dammar
Aug 13, 2016 11:02 AM
bradleyheathhays
Jul 24, 2016 03:55 PM
