KFX50 (LT-A50) overheating?
Old Dec 2, 2018 | 03:33 PM
untraceable's Avatar
Default KFX50 (LT-A50) overheating?
Now that the kids quad is getting use, I’m finding a strange issue. It appears to be overheating and killing. Seems strange, but it’s just like you hit the kill switch. The only thing consistent is it happens after running for awhile, kills like you accidentally hit the kill switch, then won’t start right away. After it seems to cool a bit, it will fire on the first pull and run as if nothing was ever wrong until it happens again which occurs much quicker now.
any suggestions on what I should be looking at? Spark plug cap and wire may be suspect, running a 5 plug. Restrictors removed and head shaved. Been sub freezing here, possibly running lean (67.5 main jet)
thanks
Old Dec 3, 2018 | 03:11 AM
Is it getting enough oil? It could be nipping up then freeing as it cools. However it could also be an ignition problem. Check the kill switches, the "sink plug" type can deteriorate and cause trouble. Check the wiring, and fit a new plug. If that doesn't fix it, the coil or exciter may be faulty, difficult to check with intermittent faults. Not sure if the LTA has a CDI as well, the LT50 doesn't.
Old Dec 3, 2018 | 01:43 PM
I guess its possible. Ive been considering bypassing the OI for awhile. Just filled the Oil tank with Amsoil Dominator when I picked it up. hardly put a tank of gas through it yet. Id like to take a look at the plug. Could def be very lean with the mods Ive done to it. since its winter, I can take some more time to work on it.
FWIW, it does run pretty good. I go 275 and I was pulling the 35lb kid in a sled behind it in snow covered grass. Sounds opposite of the LT-Z50 reviews
untraceable
Nov 9, 2018 06:45 AM
Barrera90504
Dec 8, 2014 10:04 AM
selector
Sep 17, 2003 10:36 PM
Delmustator
Jul 29, 2003 04:53 PM
RickyA
Jun 26, 2003 11:55 PM
