Xpedition 425 checgs and dies when given gas
Old Dec 21, 2018 | 02:27 PM
Jeremy Crawford's Avatar
Default Xpedition 425 checgs and dies when given gas
So, I have done about everything I can do to troubleshoot this to no avail. what happened was that the float bracket broke when cleaning so I replaced the card.
Ever sense the ATV has not wanted to run well. The carb is unlike anything I have worked with. The throttle opens the butterfly but the plunger and needed do not move up and down like I would expect.
There are 4 lines on the carb. The 2 on top facing the airbox are merely vents unless I am missing something.
Then, there are 2 spots that go to the fuel pump. I hooked them back up the way they were originally.
After this happened I figured there must be something up with that diaphragm in the carb so I ordered a new one, same deal.
Any help would be great.
It does idle fine and if I choke the **** out of it, it will rev a little higher. I feel like that needle isn't moving when it should be.
Thanks in advance.
Old Dec 23, 2018 | 07:30 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
I believe it's vacuumed controlled. are you sure the float is allowing enough gas in?
ezhoops
1) Engine problems..
19
Oct 23, 2018 04:54 PM
confusedsuzuki
Aug 30, 2018 12:59 PM
donn92
Sep 2, 2017 06:23 PM
northshoremb
Jul 20, 2009 02:49 PM
