New top, 50psi?
Old Dec 28, 2018 | 04:09 PM
woody1189's Avatar
Default New top, 50psi?
Truly baffled. My trailblazer 250 needed a top end, it's a 74 mm. New base and head gaskets, nothing is cracked, piston to wall clearance is correct as is ring end gap. Leak down performed with nothing leaking out yet compression test says 50? Wet says 125, so I'd assume rings but that's what is confusing right now since the gap is in spec. And I realize the rings need to seat, but it should be higher than that before hand. Is there a special trick to wiseco pistons I'm unaware of?
Old Dec 30, 2018 | 06:37 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
assuming the ring gaps are not lined up on the piston?
Swensy77
1) Engine problems..
11
Sep 9, 2017 09:07 AM
ScRaMy500
Jan 6, 2007 10:26 PM
Rincon650
Jan 3, 2004 12:56 PM
Thor
Where to Ride
Aug 1, 2000 11:24 AM
