220 KlfA 1998
Old Jan 23, 2019 | 07:18 AM
Benjamin Kolodziej's Avatar
Default 220 KlfA 1998
On my atv ignition switch has 2wires coming out but the tech manual shows 4wires should I change my switch
Old Jan 24, 2019 | 03:36 AM
The 220KLF had AC ignition, (unlike the KLF300 which is DC) so will need a kill wire from the CDI and an earth, to kill the spark when you switch the ignition key off, as well as the live from the battery and another wire to the starter circuit & lights. It is two separate switches inside the key switch. You can damage components if you connect it up wrongly.
Old Jan 25, 2019 | 11:18 AM
Thanks I got the ignition right .but now I have no power going to my cdi
Old Jan 26, 2019 | 03:27 AM
I got the wiring diagram from this website, and it is too small to make out colours properly, but a red and another wire come from the exciter coil in the alternator to the CDI, these provide AC power to the CDI when the engine is turning. A yellow/red goes from the CDI to ignition switch to kill the spark when switch is turned off. The CDI does not get power from the battery.
Stephen Ayers
Oct 19, 2018 05:45 PM
bks321
Dec 22, 2004 09:34 PM
wcrook1007
Nov 5, 1999 02:09 PM
Andy Bassham
Aug 27, 1999 01:58 AM
