Klx 110 carburetor on KFX50 4 stroke?
Anyone ever swap a klx manual choke carb to a kfx50 ? Or does anyone have a klx 110 carb around they could take some measurements from? ( bolt center, throat diameter, and filter flange diameter). The KLX 110 carb seems like a great option for the KFX 50 to put a genuine Keihin back on and appears to be a pb18 carb which is what’s typically used in a kfx carb swap. I’m just having a hard time getting firm measurements from one to be sure or finding someone that has done the swap. I can find a ton of knock offs for the pb18 but don’t know if there worth messing with. Any and all info appreciated, Thanks guys.
Edit: I will be doing most available upgrades to the kfx 50 when I do the carb swap, going to remove cvt collar and all intake exhaust restrictors, 17t/ 28t sprockets, deregulated cdi, I know I’ll most likely need to rejet the pb 18 carb either way. Does anyone have any recommended jet sizes?
