04 kawasaki prairie700 cooling fan not working
Old Mar 17, 2019 | 10:33 AM
prairie4me's Avatar
Default 04 kawasaki prairie700 cooling fan not working
Radiator fan not running. Overheating. I get no power to the fan. Checked fuses under seat. They are all good. Checked wire going to the fan fuse and no power there. I had key turned on when checking. I have power to the other fuses in the same fuse box. I changed thermostat and thermosat sensor. I also get no power at the radiator sensor wire terminals.. Coolant pump is working as i have good flow through radiator. I am stumped. Any ideas will be appreciated...
Old Mar 18, 2019 | 07:55 PM
Kymco 450i's Avatar
Just add a switch to overide and operate the fan manually. Some time down the road you might figure it out, but with a simple switch, you can ride now.
Old Mar 19, 2019 | 04:00 AM
There should be a feed, live with ignition on, to that fan fuse, you could jump from an accessory fuse wire to that, and everything would work, but it is better to find where that ignition switch to fuse box wire has broken as it could indicate other wires being chaffed. I would get the wiring diagram and trace it if possible.
Old Mar 19, 2019 | 05:40 AM
prairie4me's Avatar
Thanks, that was my next plan til i figure it out.
Old Mar 19, 2019 | 05:45 AM
prairie4me's Avatar
I'll check that out. Thanks
maximus817
Jul 14, 2007 01:18 PM
droil5
Apr 10, 2007 08:13 PM
droil5
Apr 10, 2007 01:38 AM
tankman
May 24, 2006 09:25 PM
showmethemud
Feb 13, 2002 08:13 AM
