Hey all, my quad is leaking coolant from what appears to be a breather hose on the motor. I'm trying to figure out where it goes so I quit spraying coolant all over the place. The screwdriver head is on the nipple that leaks coolant. The shiny piece behind the coolant hose is the nipple that leaks
I believe when coolant comes out of breather or weep hole some sort of coolant or water pump seal is leaking not sure on that model but when water pump seal goes on the four strokes I have a 500 leaks from weep hole so you know it bad Hope its been some help? good luck
