Rubber Carbi Mount
Old Apr 19, 2019 | 03:47 AM
Pollardd's Avatar
Default Rubber Carbi Mount
Hi There.
My ATV is hard to start and does not idle very well.
I don’t know exactly what it is but the theory is it is some kind of Honda Clone around 250cc
details of that search is here https://atvconnection.com/forums/sho...errerid=171427
I’m reluctant to pull the carbi until I find some parts. There is a rubber thing between the carbi and the engine and that has cracks in it. I don’t know if this is leaking air into the engine but I suspect it is and if I try and pull it apart it may fall into pieces. How can I figure out what this is and where to find one.
i see lots clone carbi’s on Ebay but none of them have this rubber manifold if I can call it that.
Any info on this funny bit would be appreciated.
let me know if you need more details. Sorry this pic is a bit average bit it’s hard to get a clear picture of it.
Thannks
David
Old Apr 19, 2019 | 09:33 AM
Zrock's Avatar
Super Quad Patrol
Most atv/dirtbikes have a rubber carb boot like that lots of different variations and some do use a solid mount.. You will have to pull it off so you can get some mesuments when you order a new one. They are all over ebay and amazon for cheap just search for you engine size and you should hit it
Old Apr 20, 2019 | 06:30 AM
Standard procedure is to spray WD or other oil onto the rubber with the engine running, if the engine note changes it is sucking air through the cracks. However I would be tempted to run some masking tape round the manifold, which should also seal any cracks and the "bodge" may last for years.
Old Apr 20, 2019 | 10:31 AM
Zrock's Avatar
Super Quad Patrol
taping is just a bandaid.. Just remember that is the tape lets go in a section it can let dust through that opening and eventually take out the engine
Old Apr 22, 2019 | 06:55 AM
Pollardd's Avatar
All good advice. I did find them on eBay. Just hard searching when I don’t really know what the engine is.
ill pull it off and take some measurements. I doubt it will survive removal very well.
so bodging it up with tape isn’t something I’ll try although I didn’t think of that.
i also see whole carbies relatively cheap on ebay. What kind of success do people have with those?
i wonder if it will be easier than trying to clean mine out or are the new ones often total rubbish?
outofline
Aug 4, 2008 07:20 PM
MrMeaner
Aug 4, 2005 01:53 AM
