Creeping Kawasaki
Old May 1, 2019 | 06:01 AM
paledarker's Avatar
Default Creeping Kawasaki
Just purchased a used Kawasaki 360, 2003 model, and it moves forward when idling. Apparently the issue is with the cvt belt, but I don't know the cause or the fix. All help appreciated. Thanking you in advance.
Old May 1, 2019 | 08:54 PM
MrSummit's Avatar
Default Creeping
Usually creeping is because the belt deflection (slack) is not great enough. There are specs for deflection.
When I installed a Carlisle belt and aftermarket primary clutch on my 400 prairie I had to add a shim to the secondary clutch because the belt was too tight.
brinkkl2000
Sep 25, 2013 09:32 PM
BigBadScrambler
Mar 15, 2003 08:53 PM
filthyhabit
May 15, 2002 11:02 PM
SilverOne
Oct 11, 2001 11:20 PM
hink250r
ATC 3-Wheelers
Jul 19, 2001 11:19 PM
