2015 400HO headlight issues. any advice?
Old Jun 8, 2019 | 11:17 PM
SOLOLUCKY's Avatar
Default 2015 400HO headlight issues. any advice?
so my boys 2015 400HO has an intermittent headlight issue where it won't come on and the tail lights and break light do not work either.
Can anyone offer any insight on a fix?
anyone had this issue and fixed it?
I checked all the fuses in the block and they are all good....plugs under the hood have all been greased...Hell the headlights worked last night...now today nothing works !! some rogue damn gremlin.
The boy said its been doing this for a while now...
any advice? where to look for a ground issue ..a plug.. I am unsure where to start or trace on this one/.
Old Jun 11, 2019 | 09:45 PM
SOLOLUCKY's Avatar
well I figured it out...it was an issue with the Main fuse...weird because it would start, dash worked, but no lights. well after fiddling with the fuse I could make the dash go dark, it wouldn't start, no power, nothing. Well I bent the spade on the fuse in different directions to apply pressure on its contacts and now everything runs and works as it should..
Anyone with issues ….check and play with that Main fuse.
idm1996
Nov 29, 2019 09:14 AM
Cole Gibert
Jan 11, 2017 09:10 AM
anad86.
Jul 28, 2015 04:57 PM
petersty07
Jun 23, 2015 07:13 AM
LIL6T8
Sep 6, 2014 12:59 PM
