Loud clunk on acceleration an deceleration 2003 700
Got a pretty loud cluck coming from maybe the transmission (but not sure) on acceleration and deceleration. Only clunks once while accelerating hard and as soon as I hear it I let off and it clunks again on the deceleration. Keep in mine this atv has a turbo and seems the clunk happens about the time I build some boost and put strain on the driveline. Thinking maybe silent chain in the transmission but wanted to get your guys opinions before tearing it down.
F.A.S.T Racing
POLARIS 800,STAGE II TURBO,CHEMICALLY INTERCOOLED,DYNOTUNE NITROUS SYSTEM,40MM CARB,TANGELO ORANGE PEARL PAINT,CUSTOM RACE CUT PLASTIC,DIRTY DAWG CLUTCHING,CUSTOM MUZZY EXHAUST,SCRAMBLER BUMPER,28" MEGA MAYHEM,NERF BARS,OIL & TEMP GAUGES,K&N FILTER,3"WHEEL SPACERS,HEADLIGHT & REVERSE MOD,2" RD LIFT,1" FORWARD A-ARMS
F.A.S.T Racing
It's always had the polaris clunk from day one when I bought it new. It put in all new u joints from front to back less than 100 miles ago. Spline yoke has also been loose from day one. This is a hard cluck while accelerating around 35mph or faster when building boost and putting a strain on the drive line. I have the transmission out. I will report back with what I find in a couple days when I have time to tear it down.
Didn't find any reason for a loud pop in the transmission. I did find a bad bearing and the silent chain to be loose. Here's some video's below. Think maybe the 4wd might be trying to kick in causing the pop but still don't know.
I'd be willing to bet that chain is most of the source of the clunk that's a lot of slop I would definitely replace /bearing too! It looks similar to the trans in my atp 500
Keep us posted as to the possible cure
I hope that is what the clunk is from. The chain touches the case on each side if I move it over with my finger. I don't see any marks on the case but it can't be far off from rubbing it. I will report back if the chain fixes it.
Yah that puppy looked stretched wasn't going to get better! how many miles on atv? I gotta watch mine.A post from mechanic on this forum said to make sure you use Polaris AGL transmission fluid [thin]in those trans says reg gear fluid is to thick and wont make its way up to top transmission bearings FYI? Hope its all it was
