Eton rascal 50 no start
Old Aug 26, 2019 | 07:16 PM
Rpete32's Avatar
Default Eton rascal 50 no start
Bought the little one a 2 stroke rascal that the owner said had carb issues. I checked it out and it wouldn’t start, sprayed a sniff of fluid and it fired right up and stayed running on choke so I purchased.
I get it home and realize all the fuel lines are rotted so I replace and change the filter... starts right up first pull no choke and idles perfect. Even pulled my 200lb butt around.
Birthday comes and he/cousins ride it for a couple hours and then one gets a bit wild and takes it through some puddles and stuff.... still no issue. I tell him to park it and I come out 1hr later and will not start. Give it a sniff of fluid... nothing. I pull the plug and it’s black and nasty so I replace and try again. Nothing. I pull the plug and check for spark and it’s got spark. Fuel is pumping and air is clean. I’m lost.!!!
Old Aug 27, 2019 | 02:48 AM
Clean the carb out, it probably has got some dirt through from those old lines or the tank bottom, which has now blocked a jet.
Old Aug 27, 2019 | 06:47 AM
Rpete32's Avatar
Shouldn’t it have at least started of the carb cleaner
Old Aug 27, 2019 | 07:02 PM
LT80's Avatar
LT80 Expert
Start from carb cleaner? I don't think so.
Old Aug 27, 2019 | 07:09 PM
Rpete32's Avatar
That’s how I got it to start before we replaced the fuel lines and filter. I would spray a sniff of carb cleaner and choke it and it would fire right up. After I replaced all the lines , new gas, new filter it would start on first pull with no choke for 2 days. They rode it for a couple hours and now it will not start and little dude is heart broken. I’ve got spark and changed the plug to be safe and still nothing
Old Aug 28, 2019 | 02:32 AM
An engine needs exactly the right air/fuel ratio to start, note that you can wind a Suzuki Eiger all day in Winter and it won't start without the choke being on, yet it runs fine without choke once warm. So you squirt in carb cleaner and, if you get the amount just right, it will fire, too much or too little and it won't. I repeat, clean the carb out.
Old Aug 28, 2019 | 05:54 AM
Rpete32's Avatar
Ok. Will pull and clean the carb. Anywhere I can buy a new carb for it just to be safe
Old Aug 29, 2019 | 02:09 AM
Alpha are the only specialist for pre 2012 Etons but, if you are reasonably careful, the carb should clean without problems.
dseals91
Apr 18, 2017 03:40 AM
fish2222
Dec 21, 2013 09:53 AM
rowebil
Apr 19, 2011 06:47 PM
ned5485
May 30, 2009 06:25 PM
normalrio
Dec 24, 2007 01:11 AM
