2014 550 Sportsman - no reverse
Old Sep 9, 2019 | 11:02 PM
highpockets003's Avatar
Question 2014 550 Sportsman - no reverse
With our '14 550 Sportsman Versatrak, the gear shift level moves to all positions and in "R" (reverse), there's no movement with the wheeler. Fewer times, there's a slight gear-grinding sound heard, but most of the time there's no grinding sound and the wheeler will not move in reverse; the P, N, L and H modes work as expected. This is all done with the engine running.
Any ideas as to why reverse doesn't work, or why the transmission won't shift into reverse?
Old Sep 20, 2019 | 03:55 PM
Okay, BUMP... to the top.
Anyone know why this model's tranny won't engage into REVERSE, but will in every other gear (P,N,H,L)?
Old Sep 23, 2019 | 08:53 AM
Kymco 450i's Avatar
I would check linkage adjustment, you could unhook linkage and see if you can manually put it into reverse. Worse case is reverse gear is stripped out or broke. My guess would be shifter linkage. Any metal parts when you drain transmission oil?
Deerkiller
Oct 22, 2008 10:08 AM
660rollover
Aug 9, 2004 02:16 PM
ArticCatBill
Jul 13, 2004 10:41 AM
terd
May 21, 2004 09:28 PM
