650 prairie carb rebuild
Old Sep 21, 2019 | 09:19 AM
Tlspruill's Avatar
Default 650 prairie carb rebuild
How much trouble is it to rebuild the carbs on a 02 650 4x4 atv by novice mechanic?
How difficult are they to remove. Service manual says to drain coolant.Why?
Old Sep 22, 2019 | 02:00 AM
I don't know the Prairie at all, but from old posts on here, setting the carbs on the V twin has proved impossible for a lot of ATV repair shops. I would be very wary of doing anything other than a clean, and I mend Quads for a living.
Old Sep 23, 2019 | 08:49 AM
Kymco 450i's Avatar
The rebuild is like any other carb, needs a clean work area and you need ro go slow and be precise and also use a good kit so you have all the proper settings. The trick is getting rhem matched to run together properly. I have done outboard motors with multiple carbs and special tools and vacuum gages are needed to syncronize the carbs or it wont run right.
Old Sep 23, 2019 | 09:55 AM
Tlspruill's Avatar
Thanks guys. I'm going to attempt to just clean the carbs . Looks like air filter element disengaged and got sucked into the carbs..😯
POLARIS NOOB
Jul 1, 2009 09:17 PM
hines57
Nov 10, 2005 06:12 PM
DennisC
Feb 26, 2003 11:41 AM
