eton 50cc will not stay running unless..
Old Oct 16, 2019 | 09:30 PM
gamegodessss's Avatar
Default eton 50cc will not stay running unless..
If I unhook the hose going to air filter and place my hand over the hose it will start and idle but as soon as I take my hand off it dies. Any ideas would be great. I have no idea what year it is.
Old Oct 17, 2019 | 02:51 AM
You are in effect running it "on choke". An engine that will only run when choked is running weak, usually due to a partly blocked jet in the carb. Remove the float bowl and jets, then clean the jets out with compressed air, Blow through the holes they came out of too.
Old Oct 17, 2019 | 08:19 AM
LT80's Avatar
LT80 Expert
If it still has a issue after that, do a compression test.
Old Oct 20, 2019 | 07:23 PM
okay thank you I will do as you suggest. Will let you know how it turns out
grapejuice420
Jun 29, 2016 06:30 PM
williams8125
1) Engine problems..
Dec 18, 2014 03:52 PM
capebreton1967
Apr 12, 2011 07:23 AM
keondgo
Jan 13, 2004 07:29 AM
395r
Dec 24, 2002 02:41 PM
