2008 Kawasaki kfx 450 front sprocket locked
Old Nov 8, 2019 | 08:37 AM
Bdnova72's Avatar
Default 2008 Kawasaki kfx 450 front sprocket locked
Howdy y’all I have a 2008 Kawasaki kfx 450 and I was riding doing 3rd gear donuts in a field bouncing off rev limiter because it was a party and the chain popped off and caught between the swing arm and front sprocket the front sprocket is locked up so I started taking the engine apart because I think it’s a bent counter shaft/ transmission is binded up this is my first engine rebuild I’ve done a top end on my banshee but nothing compared to this I’ve never even gotten into a bottom end and I can’t find anything about it online about anything, dirt bikes or quads it still ran (before I took the motor apart) just with the clutch pulled in but when you let go it dies and it claims to be in nuetral because of the light but I’m pretty sure it’s stuck between gears there was also oil leaking pretty bad out of the sprocket and I’m pretty sure it’s just the gasket behind the sprocket so I might replace the crank since I have it tore down but it’s a low hour bike so I don’t know if I want too yet any help would be greatly appreciated also I will probably see stuff if you dm me on Instagram:bdnova72 thankyou
masterp0606
Mar 25, 2008 02:58 AM
OrangeKFX
Nov 9, 2005 11:37 PM
kawiking
Aug 10, 2005 01:00 PM
