KLF/Bayou 300 starter issues
Old Dec 1, 2019 | 12:27 PM
klfken's Avatar
Default KLF/Bayou 300 starter issues
Had some issues with my bike a while back and in the process seems ive done something with the wiring or starter issue as the starter i believe is turning the wrong way now!?
Here is a video of it.
https://www.youtube.com/watch?v=eWOvoXY1xr8
Unless i am mistaken it looks like it's turning the wrong way it's trying to turn the crank Clockwise when it should be counter clockwise surely.
I checked the main starter cable is running from the positive terminal to the solenoid. Therefore it's wired right isn't it? As of course the starter only has one wired connection and uses chassis negative earth.
Any thoughts appreciated.
Old Dec 1, 2019 | 09:05 PM
Bill Hilly's Avatar
Did you have the starter apart?
Old Dec 2, 2019 | 03:34 AM
If the starter is turning backwards, it is usually because the brushes are the wrong ones. Never had the problem with Kawasakis, but I have fitted the wrong ones to Yamahas. The brush kits have L and R stamped in the metal, and the new brush kit has to match the old one. If you bought a new starter motor, it must be for a different bike.
Old Dec 2, 2019 | 09:15 AM
klfken's Avatar
No it was fine i fitted this starter and it was working fine. I had some issues with the CDI and ignition but fixed them, around that time i noticed the starter was wizzing. It's like ive connected the battery the wrong way?
Now i've traced the negative from battery and that cable goes to the chassis and the other heavy cable from positive (+) goes to the right hand node on solenoid!!
If i reverse wire the battery to test can i damage ignition etc?
Old Dec 2, 2019 | 10:06 AM
klfken's Avatar
No i bought it as a new unit about a year ago and when first fitted it, it worked fine. Only since i was working on an ignition problem with bike hadn't started it for a while then the solenoid failed.
Old Dec 3, 2019 | 02:54 AM
Do not reverse battery polarity. It should blow a fuse but may also blow CDI or regulator. Check with a voltmeter that someone hasn't charged the battery backwards, unusual but possible. There is an epicyclic gearbox inside a Kawasaki starter motor, just wondering if it is possible for a fault in it to make it run backwards. If battery polarity is correct, there must be a fault inside the starter motor somewhere.
Old Dec 3, 2019 | 06:01 AM
klfken's Avatar
Tanks Merryman for your input here too, just jogged my memory i still have the old spare starter so going to spin that up see what direction it goes. Cheers.
Old Dec 4, 2019 | 03:25 PM
klfken's Avatar
OK i swapped out the starter motor back the original and now it starts ok, and the old starter motor turns in the opposite direction someone mentioned as a good ref the same direction the wheels turn, ie anti clockwise.
My new starter turns clockwise.
Old starter here (works ok turns correct way):
New starter here (turns wrong way and spins on clutch)
As you may appreciate i am completely at a loss and the quad bike company doesn't want to exchange it for me
Old Dec 5, 2019 | 03:16 AM
Take a look inside the faulty starter. My guess is something wrong with the brushes or holder, Probably moved round, as the plate they sit on is positioned by a small tab. Though the epicyclic gearbox at the sprocket end of the starter is, as I mentioned earlier, a remote possibility.
lochsaelk
Ask the Editor
Aug 26, 2016 09:22 AM
Rickybobby1118
Dec 1, 2013 01:23 PM
Jsellers
1) Engine problems..
13
Jul 16, 2012 12:19 AM
randallp504
Dec 4, 2007 02:21 PM
Sp00ky
Apr 9, 2006 01:41 AM
