Banshee ??????
Old Apr 26, 2001 | 03:53 PM
latervikes's Avatar
Can any of you Banshee owners tell me about any after market mods to get better low end power out of a Banshee?
Old Apr 26, 2001 | 08:19 PM
Zorro's Avatar
A 2into1 pipe will do the job. Dynoport is the most extreme (2 into 1 headpipe), while you can get Paul Turner midrange, FMF gnarly or DMC, if you don't want to loose too much top end.
More compression helps, as well as reed spacers...and let's not talk about big bore or even better, power valves.
Old Apr 27, 2001 | 10:29 AM
sAyIt_fmf's Avatar
As mentioned....A 2 into one pipe set will work.
Even easier is dropping a tooth on the front sprocket. You will not loose much on the top end.
Another thing would be to increase the compression with the likes of a cool head with interchangeable domes. Or mill the head for a less costly method.
Some of the stumble off the line can be cleaned up with a new pilot jet. Which again, is very cheap to do.
It depends on how much you really want to spend.
Old Apr 27, 2001 | 05:02 PM
Jennifer's Avatar
Single carbed mine and it seems fine, lower front sprocket tooth (12-13), pipes are always fun too.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
