Front End Squeaking Sportsman 700
I’ve got an 05 polaris sportsman 700 that squeaks in the front end when you drive it. Almost sounds like a rotational squeak but i’m not for sure. Just put brand new bushings in the front (and rear) and the u-joints don’t seem to be wore out. What could this be??
Many machines squeek after a while, if you have any grease fittings make sure they are greased. My machine has only a few zerks so I grap a can of PB blaster dry lube and soray the hell out of anything that moves. Being a dry lube it wont attract crud. Keep the lube away from the brake pads and rotors!! I use a whole can and flush out every joint I can reach, so far I havent had any squeeks. I do this a couple times a year. From talking to others I know this has helped there squeeks.
