Hey, guys. New here, and i need some advice.
Old Jan 13, 2020 | 02:45 PM
Bayou2's Avatar
Default Hey, guys. New here, and i need some advice.
My 1986 Bayou 300B lost spark. Not all of a sudden, it just started running like crap. Put new coil and battery in it. New piston& rings. New carb. New plug. Fresh fuel. Then i noticed it was only sparking like once every 5 times the motor turned over. Intermittent at best. If anyone has any suggestions or ideas, i would greatly appreciate the help. About the only thing i haven't messed with is the igniter and magneto.
Old Jan 14, 2020 | 03:30 AM
Make sure you have good positives at igniter and coil. Make sure you have a good negative at igniter. The pulse wires should produce a small AC voltage (black/white and blue wires) when the engine is spun with the starter. If all that is good, I would change the igniter, cheao Chinese ones are available, though the 86 KLF300 is a bit different to all others, so I'm not certain the igniter is the same, the alternator and pulse coil is different.
Old Jan 14, 2020 | 06:09 AM
Bayou2's Avatar
Thanks, brother. Im terrible with wiring. I had no idea what the problem was. I'll get back to you and let you know if that was the issue. I appreciate your time.
holi66
Aug 6, 2017 12:40 PM
Draino
Oct 23, 2015 02:34 AM
Dakotablood
Nov 2, 2012 05:59 PM
yfm80moto4
Dec 22, 2007 03:42 PM
madmartin
Aug 29, 2007 02:29 AM
