Kfx80 youth quad won’t start
Old Jan 18, 2020 | 01:08 PM
BoHunter0210's Avatar
Default Kfx80 youth quad won’t start
Bought a used 03 Kawasaki kfx80 for my kids. Machine has been running great for a week. Went out to start it last night and it won’t run. It cranks but won’t start. The temperature is quite a bit colder than it was a week ago, nearly 20-30 degrees colder. But I wouldn’t think that would make the machine not run. Any help would be great.
Old Jan 18, 2020 | 02:26 PM
Bill Hilly's Avatar
i know some will disagree but give the air filter a good shot of starting fluid and see if that helps.
Old Jan 18, 2020 | 02:46 PM
Tried starting again. It cranks but the more
i crank it the cranks seem to slow down. Could it be the battery needs a charge?
Old Jan 18, 2020 | 02:56 PM
im new to these quads. I’m no mechanic but I’ve been known to fix things on cars. How can I spray it directly to the filter? Seems to be pretty difficult to get to the filter.
Old Jan 18, 2020 | 03:05 PM
Kymco 450i's Avatar
Before doing anything be sure battery has a full charge. Without full voltage nothing is gonna work right.
Old Jan 18, 2020 | 03:26 PM
I will check that first
Old Jan 18, 2020 | 07:12 PM
Bill Hilly's Avatar
Yes! Do charge the battery.
You dont need to actually spray on the filter. Remove the seat and just spry in the filter box using the air intake holes.
Old Jan 19, 2020 | 02:58 AM
Air box isn't under the seat if it is the same as the Suzuki LT80. There is an air pipe from airbox to belt cover, I just remove one end of that and squirt gas from a gas blowlamp down it into the airbox. Less dangerous to the engine than "easy start" fluids, and can't "wet the plug" either.
Old Jan 19, 2020 | 09:56 AM
LT80's Avatar
LT80 Expert
LT80's (KFX80) are cold blooded. In very cold, they can require a lil heat blown on them. A lil starting fluid won't hurt.
Old Jan 19, 2020 | 03:54 PM
Thanks for suggestions. Haven’t had time to try anything and the next few days are supposed to be cold (in the 20’s for highs). Kids won’t ride until it warms up some
