Kawasaki klf110b parts needed
Old Jan 22, 2020 | 05:55 PM
cabz's Avatar
Default Kawasaki klf110b parts needed
Hello.
It seems that I cannot find any of the parts I need to rehab my sons atv.
the carb got lost in a move and it has no spark , does anyone have an idea on a carb i can use? or a wiring diagram I could look at?
Old Jan 30, 2020 | 03:54 AM
A bit of an odd one, there doesn't seem to be any choke mechanism on the original carb. I would go for a 22mm (PZ22 or VM22) Chinese replacement. If you have the inlet flange it may be an easy fit, if you don't, you will have to make an adapter inlet manifold. A quick Google of "Kawasaki 110 wiring diagram" fetched up the KLX110 diagram, it may be similar and is so simple anyone could follow it. If that isn't right, get a workshop manual, it will have the diagram plus ignition circuit tests in it.
Just noticed a Chinese 20mm carb on eBay that has no visible choke mechanism, could this https://www.ebay.co.uk/itm/50cc-90cc...8AAOSwy8JdcN3g be the same as OE?
Bleach
1) Engine problems..
16
May 16, 2021 08:23 AM
sparkman
Apr 25, 2010 10:26 AM
Texasbuddie
Jul 9, 2008 04:37 PM
learnem
Feb 15, 2007 03:44 PM
springdrl
Dec 2, 2000 12:29 PM
