04 sportsman 400 issues
Old Feb 26, 2020 | 08:21 PM
Sportsman40004's Avatar
Default 04 sportsman 400 issues
Atv had been sitting a while had bad gas in it.
would not run up to this point I have put a carburetor on it , drained all gas and replaced the spark plug and now when you turn the key on and use the pull starter it will start and idle but will cut off when throttle is applied it will not restart until you turn the key switch off and then back on like it is resetting something The battery is dead but it is hooked to a battery charger getting 12 V. Could that be what is causing it to cut off? I didn’t want to spend the money on a battery if I cannot get it running if that makes sense
Old Feb 28, 2020 | 11:50 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is the charging system working? not sure if the battery charger would be a replacement if not charging as it would need a 12+ volt to keep running. just a thought.
Old Mar 1, 2020 | 06:11 PM
ok installed new battery and that seemed to do the trick thanks for the help
Jason Bunn
May 29, 2018 12:59 PM
RazorSharp
Jan 4, 2011 03:32 PM
nitro4you
Jun 14, 2010 08:08 AM
Elimin8r
Sep 23, 2008 01:38 PM
Gunx34
Sep 22, 2004 05:31 PM
