Raptor Jetting
Old Apr 27, 2001 | 10:36 AM
ChrisMac's Avatar
Why does everyone refer to 2 jet sizes when talking about the Raptor. Like this taken from a previous post
155/150 mains w/ 27.5 pilot did the trick
Did he put a 155 in one carb and a 150 in the other?? Also I plan on getting an E Series slip on what jetting should be about right??? I'm at sea level.
Mac
Old Apr 27, 2001 | 01:02 PM
xtreme165's Avatar
ChrisMac, Each carb has a main jet in it and one side uses a bigger main. You may not even have to rejet with e-series slip on call WB and see what they reccomend. Plus most impt when you get pipe on check plug to make sure your not running lean no matter what someone tells you, if you check spark plug it will tell you the truth.
Old Apr 27, 2001 | 03:36 PM
AZLandscaper's Avatar
the right carb feeds 2 intake valves and the left carb feeds only one. The increased airflow thru the right carb requires a larger main to flow more fuel.
bmxatv10
Oct 14, 2022 06:23 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
