Kawasaki KFX 400
Old Apr 3, 2020 | 05:06 PM
Matt Griffis's Avatar
Default Kawasaki KFX 400
OK I have A kawasaki KFX 400 are just bought a brand new card and put it on and everything but now when I crank it up to run it the throttle is getting stuck wide open no matter if I turned idle screw down it's still doing any suggestions
Old Apr 4, 2020 | 02:00 AM
Either the cable is sticking/not adjusted properly, or the new throttle has a sticky butterfly shaft. If it is the cable, there won't be any slack at the carb end of the cable when the fault is on. If it is the butterfly, there will be slack in the cable but the lever/quadrant will not be touching the throttle stop. If it is touching the stop, air getting into the joint between carb and inlet manifold is a possibility, or you just haven't backed the stop off far enough.
Old Apr 11, 2020 | 04:45 PM
Default Reply
I cleaned my old carb & put a new needle in it but it is doing the same thing. But with the old carb it will start up fine then gradually increase till its wide open. Nothing is wrong with the throttle cable. Could it have something to do with the TPS sensor on the side of the carb? The new carb don't have a spot for the TPS sensor on it but the old one does. Will that cause it to do what's its doing?
Gills04yfz
Jun 9, 2004 12:07 AM
IronBear
Aug 2, 2002 04:14 PM
