2003 Polaris scrambler cylinder base torque spec(12mm bolt)
Old Apr 5, 2020 | 09:46 PM
Bigben01's Avatar
Default 2003 Polaris scrambler cylinder base torque spec(12mm bolt)
2003 Polaris scrambler cylinder base torque 12 mm bolt
Old Apr 6, 2020 | 06:30 AM
scootergptx's Avatar
Supersock
Hired Gun!
$5 for a service manual is a good price and a good investment.
Here's what I've found in here, note that it's for the 2x4, not 4x4. Not sure if there would be a difference.
CYLINDER bolts tighten in three stages crisscross pattern up to 46 ft lbs 2 smaller 6mm bolts 6 ft lbs
CYLINDER HEAD a little trickier here goes
criss cross pattern torque to 22 ft lbs
then torque to 51 ft lbs
loosen bolts evenly 180 or 1/2 turn
loosen another 180 or 1/2 turn
retorque bolts to 11 ft lbs
from this point tighten bolts evenly 90 degrees 1/4 turn
finally tighten another 90 degrees or 1/4 turn
install two 6mm bolts and torque to 6 ft lbs
note I'm not a Polaris mechanic LOL
Old Apr 6, 2020 | 08:52 AM
Bigben01's Avatar
Thank u ordering one now
Bigben01
Apr 5, 2020 09:34 PM
Bigben01
Apr 5, 2020 09:25 PM
Ehall8702
Jun 7, 2018 07:51 AM
tennesseeduck
Aug 11, 2004 02:20 PM
