Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
Eton Viper 70 has me stumped
Old Apr 5, 2020 | 11:15 PM
KingQuadRider7's Avatar
Unhappy Eton Viper 70 has me stumped
I just rebuilt a viper 70 because the compression was low, and a rebuild kit for this quad is cheap. So I finished it, made sure I put the piston in the right way, oiled everything as I was assembling it, and it will not start. Only will it backfire out of the exhaust every once in a while while I am cranking it over. It has good spark, is full of fuel, air filter is clean, and i just cleaned the carb. Any ideas on what may be wrong?
Old Apr 6, 2020 | 09:37 AM
LT80's Avatar
LT80 Expert
Plug getting wet?
I'd check the compression (yes I know it's new).
Old Apr 6, 2020 | 09:44 AM
Originally Posted by LT80
Plug getting wet?
Yep the plug is getting wet. I've even tried squirting fuel directly into the combustion chamber and it still only backfires. I guess I'll check the compression today and let you know.
Old Apr 6, 2020 | 12:25 PM
Default I think I found the problem
Old Apr 6, 2020 | 12:41 PM
It only has 25psi of compression. What would you recommend I do.
Old Apr 6, 2020 | 07:28 PM
LT80's Avatar
LT80 Expert
I'd get your oem cylinder bored to a oem piston.
No more Wuhan specials.
Old Apr 6, 2020 | 07:37 PM
I am still using the oem cylinder. All i replaced was the piston, rings, and gaskets of course.
Old Apr 7, 2020 | 08:45 AM
LT80's Avatar
LT80 Expert
OK. Did you get a bigger piston and have the cylinder bored to it?
79hugger
Aug 23, 2007 09:42 PM
glassman181
Feb 12, 2007 06:00 PM
