2003 Kawasaki Prairie 360 Starter Hangs
Old Apr 12, 2020 | 06:54 PM
CLS_2012's Avatar
Default 2003 Kawasaki Prairie 360 Starter Hangs
I just purchased a Prairie 360 from a friend and knew it had a few issues such as needing to replace the LED Indicator which I have ordered but my big issue right now is the starter is hanging up and not starting. I hit the electric start and it will spin the starter and when I let off the button the starter changes pitch and just keeps going even when the ignition is turned off. I have to disconnect the battery to get it to stop. Anyone have any ideas on what the issue might be? TIA
Old Apr 13, 2020 | 11:08 AM
Kymco 450i's Avatar
Remove starter and clean, might have some crud build up in there. Inspect pinion gear for damaged or missing teeth, if there are then you might have to dig deeper but you might get luckey and find your problem
50pinch
Aug 23, 2009 04:14 PM
DUNNAR
Jan 1, 2008 04:26 PM
lancems007
Apr 15, 2003 02:07 PM
lancems007
Apr 11, 2003 08:11 AM
