Trx90 hesitation/stall
Old Apr 26, 2020 | 10:01 PM
Mrblue01's Avatar
Default Trx90 hesitation/stall
Just bought this trx90 for my kid to go jr drag racing. Starts easy, idles smooth, good power through the rpm. BUT if you stab the gas quickly from idle, it will stall, or at least bog badly. It was also leaking gas (float valve sticking), so I bought a Chinese replacement carb. It fixed the leak but not the stall. Tuned for best idle, good plug, checked for air leaks with carb cleaner, fresh gas, does it in neutral or in gear. I have searched and found lot of similar issues, but no confirmed fixes. Need to get this figured out as drag racing will be hitting the gas hard from idle.
Old Apr 27, 2020 | 08:12 AM
LT80's Avatar
LT80 Expert
Check valve adjustment and compression.
Old Apr 27, 2020 | 03:19 PM
Mrblue01's Avatar
thanks for the reply. I did the valves today... they were both fairly tight (1/4 turn to get them to 0.002”). It didn’t fix the issue, but its a bit more clickity. I also checked leakdown- 96ish, so the should be ok.
anything else?
JD11
Mar 27, 2016 08:26 PM
Quad215
Sep 15, 2009 03:21 PM
Vaughn
Aug 13, 2009 04:31 PM
mountainclimber
Dec 10, 2005 03:08 PM
snowbuster
Sep 13, 2004 10:22 PM
