Whining noise from front differential, normal?
Old Apr 28, 2001 | 07:07 PM
tealboy's Avatar
I have a 300 4x4 Honda and noticed when i am running fast, 4th or 5th gear, I hear a whinning or humming type noise from the front differential. It may be perfectly normal but I have never owned a 4x4 before. Plus, i got this one used so i don't know if it made such a noise when new. It doesn't sound bad, but it is noticeable enough that i thought i would ask for your opinion. The front wheels seem to spin and work as they are supposed to so maybe it is nothing.
Old Apr 29, 2001 | 04:53 PM
Iowahuntr's Avatar
I would suggest changing the front diff fluid and look at the old fluid to see if it is contaminated in anyway and also look at your front wheel bearing. Also what kind of riding are you doing. Might be some tire noise if its on pavement ect...
Old Apr 30, 2001 | 11:10 PM
honda450s's Avatar
i hear the same whinning noise on my 450s it's done it since day 1. I asked the dealers and he said its nothing to worry about
Old May 1, 2001 | 11:54 PM
BlueHonda4x4's Avatar
I wouldn't worry about the whining noise. Both mine and one of my friends 300 4x4's have the same whine.
If you listened close enough about any 4x4 while whine a little from the front end. So I doubt it is anything to worry about.
Old May 2, 2001 | 12:17 AM
Michaud68's Avatar
There Is an additive you can add that will stop the whining noise I can't remember the name but i'll post it tommorow
Old May 2, 2001 | 11:16 AM
ex_master's Avatar
My 300 4x4 has made that noise from day 1 and I've never had any problems with the front diffrential.
Old May 2, 2001 | 02:06 PM
I thought the additive stuff was to quieten clutch chatter in the differential wasn't it?
Guess it might help the wine too.
Most people on here say to go to your local cheverolet dealer and ask for the additive stuff. I don't know if I have ever seen a name for it on here. I guess you just ask for a bottle of gear oil or differential additive. The stuff probably isn't limited to cheverolet either.
Old May 2, 2001 | 07:30 PM
Michaud68's Avatar
The additive is called GM limited slip lubricant it helps quiet the differential.
Old May 6, 2001 | 04:46 PM
Rancher4x4ESLuvr's Avatar
My rancher (and all ranchers as I take it) make the same whine in 5th when you give it gas, its pretty cool, sounds like a turbo lol.. Dont worry about it.
Ride HARD, Honda.
hondarider1234
Jul 21, 2015 11:53 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
D-Hagz
Jul 4, 2015 02:19 AM
