Yamaha raptor 50
Old Sep 17, 2020 | 07:43 PM
Kyleo's Avatar
Default Yamaha raptor 50
Hello I have a 2006 Yamaha raptor 50 for my boy that I can’t get to run. Has spark when I test the plug against the block. Plug is wet so has fuel. Compression is good. This thing will not fire I get the odd backfire but it will not go. Any ideas would be greatly appreciated. Is it possible there is no spark under compression?
Old Sep 18, 2020 | 02:32 AM
Are you sure, certain, positive, you have good compression. That engine is notorious for the valve clearances closing up and dropping the compression at cranking speeds. Set valve clearances anyway, it can't hurt. If they are correct and it still won't go, clean the carb out. An engine needs just the right fuel/air ratio to start, which is why some won't start without choke.
Cody Hammons
Mar 21, 2013 05:25 PM
RUBBERDUCK198
ATC 3-Wheelers
Jul 28, 2006 10:49 PM
caliraptor
Mar 7, 2005 08:28 AM
Up2nogd
Oct 29, 2004 10:08 AM
