250X
Old Apr 29, 2001 | 10:04 PM
zeebo's Avatar
I just bought a honda trx250x and it has a an exhaust system and has been rejetted . I need to know some things i can put on it or do to it to make it smoke a 2001 300ex. any comments would be appritiated ! thanks !
Old Apr 30, 2001 | 06:43 PM
DSAPP's Avatar
a pipe and jetting ought to do it!
Old Apr 30, 2001 | 09:52 PM
Need4Speed's Avatar
Nothing! Even a stock X will beat the 300 since it has a higher compression piston. I raced my friends 300 against my X and we switched machines to see if the results were the same. The EX had the X till 3rd gear and then the X pulled away.
Old May 1, 2001 | 10:52 PM
zeebo's Avatar
Thanks for all the help (ha) I allready have a pipe and jet and mine is not faster than a 300ex! Also are the gear ratios the same on both machines
Old May 2, 2001 | 08:32 PM
Mike300ex's Avatar
Yes, is it possible that the rider on the ex is a better rider or maybe he is shifting faster/sooner/later?
In reality they should be about the same. The x has a slightly higher compression piston but the ex has more cc's so it should be pretty close. BUT if you have a pipe/jets and still cant smoke him and he's stock then something is wrong because if anything the pipe/jets should definately make you faster than stock.
Old May 2, 2001 | 10:07 PM
zeebo's Avatar
I am having a problem with it though it wont rev up and when i snap the throttle it just goes numb like the choke is on or something . I will try using 93 octane but who knows if that will help! any suggestions would by helpful i just got it and cant figure what is wrong i changed the plug and nuttin! DAMN IT!
Old May 3, 2001 | 09:50 PM
bermbanger's Avatar
Well its got an aftermarket exhaust so the carb will probably need rejetted.
big_g_squared
Jun 28, 2015 04:17 PM
rockrider
Feb 20, 2001 02:51 AM
owen350x
Jul 30, 2000 01:58 AM
99_warrior_350
Jun 26, 2000 04:50 PM
YellaTerra
Mar 30, 2000 04:38 PM
