Extra wiring, please help Identify!
Old Oct 17, 2020 | 09:32 AM
sbash's Avatar
Default Extra wiring, please help Identify!
Ordered a new harness and everything lines up but these extra wires coming out of the engine next to the stater wires. There is also some kind of switch coming out of the rear of
extra plug that come out of the engine next to the stater
switch that was mounted to the rear of the Quad
same wiring coming out of the engine next to the stater
the qaud. Do I need these wires hooked up and what are they for.
Old Oct 20, 2020 | 09:42 AM
Zrock's Avatar
Super Quad Patrol
the middle picture is a tether/break away switch
Old Oct 21, 2020 | 03:26 AM
Usually you get stator wires for battery power, trigger coil wires to CDI and exciter coil wires to CDI coming out of stator housing. If you have all these accounted for, there could also be gearchange light/indicator wires, these would not be needed unless the neutral indicator wire also goes to the starter solenoid, so it can only be started in neutral. Probably pale green/red, check if it goes to the solenoid.
neil1911
1) Engine problems..
Jan 19, 2025 03:44 AM
sbash
Oct 14, 2020 04:33 PM
Zellet420
3) General Discussions..
Sep 6, 2018 10:41 PM
Zellet420
Sep 6, 2018 10:28 PM
Cory Inkster
Aug 7, 2018 04:54 PM
