400ex throttle adj
Old Apr 30, 2001 | 12:23 AM
new400ex's Avatar
I've heard that the throttle on the 400ex's aren't adj right, i.e. don't open to their full capacity, how do i inspect to see if my 400ex needs to be adjusted and how do i do it
Old Apr 30, 2001 | 09:01 AM
SLB300EX's Avatar
To make sure the throttle is opening all the way, you can do this:
Remove the air boot from the carb. Look inside the carb, make sure the slide that goes up and down is completely out of view when at full throttle.
To adjust if need be, pull back rubber boot on throttle cable at the thumb throttle. Loosen lock nut, turn cable counter clock wise til you have no less than 1/8" play in thumb throttle. Tighten lock nut.
You're done.
If this is too confusing, e-mail me and I'll try to clear it up.
Good luck..ours were adjusted OK.
Later....Sher
2quiker
Mar 22, 2022 08:36 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
