broken bayou 400 camshaft still usable?
Old Dec 27, 2020 | 11:57 AM
AtvNoobie34's Avatar
Learning2Fix
Question broken bayou 400 camshaft still usable?
my broken bayou 400 camshaft
Broke my camshaft somehow not properly removing the chain. Sits in the grove and doesn't rub but dont know
how it would react at 3000 RPM plus. Any thoughts, really hard to find part Thanks for any your time and advice. Happy Riding
Old Dec 28, 2020 | 03:43 AM
Personally, I would think it will be OK, it will alter the balance, but I think a camshaft is going to be a bit unbalanced anyway, with those lobes offset to one side.
Old Dec 28, 2020 | 05:50 AM
Learning2Fix
@merryman could any other really bad damage possibly happen i don't wanna loose a whole head assembly 4-5 hundred vs a camshaft @170 dollars I understand at the end of day its my call. but thank you so much for your help and advice. Happy riding friend
Old Dec 29, 2020 | 03:52 AM
It is always a gamble. I frequently rebuild Honda air cooled engines that have seized. First one I did, I found the gudgeon (wrist) pin had seized and scored the con rod eye. I cleaned it up so the new pin would fit and with a new piston and rebore, "risked it". That engine had a hard life afterwards, but is still going 15 years later, as are the 30+ engines, which also had seized small ends, that I have done subsequently.
Old Apr 7, 2021 | 03:29 PM
Learning2Fix
I ended up running the original camshaft with that chip in the disc , everything has been smooth with it so far thanks again for all your help.
Happy Riding.
duner450
Jan 27, 2011 07:01 PM
bayou fanatic
Dec 11, 2010 04:07 PM
frano
Sep 17, 2000 12:05 AM
XLR8
Apr 14, 2000 08:06 PM
