Lost
Old Jan 24, 2021 | 08:55 AM
Easyg0n_1's Avatar
Default Lost
06 brute force 750 fresh rebuild new starter and solenoid. Still just clicking solenoid. Too much compression? Can't pull rope start enough to attempt a start. Please help.
Old Jan 25, 2021 | 04:11 AM
Flat battery, earth lead off or loose, battery leads loose. Take the plugs out and check if it turns over OK with no compression.
Old Jan 25, 2021 | 08:52 PM
Kymco 450i's Avatar
I tried pull starting my Praire 300 years back, had no sucess spinning it over fast enough! Cant imagine pull starting a v twin engine.
I agree with Merryman, probably a low battery or a poor connection. Battery needs to be 12.6 vdc or higher for a full charge, 12.0 vdc or below is considered dead.
Old Jan 25, 2021 | 10:26 PM
Easyg0n_1's Avatar
So I got it to turn over. Now I It cranks but doesn't even try Q fire I'm getting spark getting fuel getting air so kind of frustrating even if I spray at the little bit of ether in breather Still doesn't try to start
Old Jan 25, 2021 | 10:28 PM
Easyg0n_1's Avatar
I sure would like to know where all of my vacuum lines if that's what you wanna call them are Going to throughout the 4 Wheeler and carbs
Old Jan 26, 2021 | 03:53 AM
Check timing of valves and spark. Don't know the Brute at all, farmers won't buy anything over 500cc over here as petrol costs a lot, but as a V twin, each cylinder will have a different spark timing.
Old Jan 26, 2021 | 04:51 PM
Easyg0n_1's Avatar
Thanks for the reply I have done all that more than once just can't figure it out sounds like it's not getting fire but I am getting spark granted I haven't tested nor do I know how to test my coils to see how much spark I'm getting
SKALESPLITUR
Dec 22, 2020 11:23 PM
Branden Collard
Feb 16, 2020 10:55 PM
Buck Mark
Apr 24, 2018 11:13 AM
Cutty
Jun 5, 2010 04:22 AM
nspctr1
ATC 3-Wheelers
Jul 23, 2008 06:37 PM
