2004 polaris sportsman 700 4x4 wont run , it wnt start or turn over or get any power
Old Feb 24, 2021 | 07:07 AM
Paul Austin Sherwood's Avatar
Default 2004 polaris sportsman 700 4x4 wont run , it wnt start or turn over or get any power
my 700 polaris sportsman wont start or run
its nt getting any power to do anything amd i dnt knw a whole lot about them
I baught from a guy whem he got it , it didmt have any dash lights or anything or front light
idk where to start or anything
I tried to cross over the starter and it didnt even do anything
Old Mar 23, 2021 | 04:08 PM
Brad Lehmann's Avatar
Start with the battery. If you don't have power there, you can't have it anywhere else. Get yourself a cheap volt/ohm meter as it is really hard to work on electrical problems without being able to tell if there is voltage present or if something is burned out. Once you know that you have voltage in the battery, you should get an indication that it is moving around the various circuits when the switch is turned to the on position. I.E. lights, starter solenoid clicks, fuel pump hums...you get the idea.
Twins616
Mar 3, 2020 05:47 AM
AZBanshee01
Jul 26, 2012 11:13 AM
pg_etrn
May 20, 2008 08:39 AM
