Lifan 250cc REVERSE gear (?)
Old Mar 29, 2021 | 01:06 PM
Jakob Benjamin Vosbein Wiltrup's Avatar
Default Lifan 250cc REVERSE gear (?)
So.. i got my hands on a 250cc 2 cylinder, Lifan ATV.
I've had a hard time figuring out, which exact model, but the closest i get is a "LC250 Viking"... Runs and drives..
Anywhow. The cluster has an "R" light, that lights up whenever i shift down from 1st, - neutral - R..
but i get nothing. Still neutral.
The wiring is a mess, and i am starting to wonder, If some wiring to the gearbox, is needed for the reverse to engage..
i have a cable with 6 very(!) thin wires coming from around the gear/gear-pedal.
they go to a connector, that only leads 2 of those wire, on to front.
When i unplug that.. plug, the R-light dies, so that's probably all those 2 wires do..
So help me out... Does anyone have one, the same as mine ? How do you engage reverse ? Does anyone have a wiring diagram ?
Do i even have a reverse gear, or is it somehow just.. "prepared for reverse retrofit"... Something??
Pardon my English... I am danish afterall
Old Jul 5, 2022 | 02:41 PM
MadAtv's Avatar
Default 250cc
Hello, I’ve got a 250cc atv as well and same 2 wires go from the 6 pin that comes out of the engine, did you figure out how to put in reverse?
Looked everywhere online and can’t seem to find an answer.
Thanks!
Old Jul 5, 2022 | 03:03 PM
MadAtv's Avatar
Hello, I have very similar quad with 250cc jetmoto engine with the same 6 wires coming out and going into the 2 wires that are connected. The issue I have is same as yours where I cannot go into reverse, did you fix it yet? If so, can you please let me know how you did it! Thanks!
Old Apr 23, 2026 | 03:43 PM
TINI's Avatar
Does your bike have this,
Handle of the reverse gear
Reverse gearbox part of diff, with lever type pulley on top.
Boetie
Jan 14, 2018 09:56 AM
1967Firebird
1) Engine problems..
Apr 18, 2015 09:23 AM
swapy2008
Technical and How-To Articles
Oct 6, 2008 03:56 PM
cia_gov
Jul 14, 2008 11:34 PM
